Covenanter said:
nopiano said:
Covenanter said:
Won't make any difference, a complete waste of time. Buy some music instead.
Chris
How do you account for the review's findings then, Chris? Expectation bias; a bundle of tenners in the review sample; or something else?
WHiFi don't do blind tests so their reviews are purely subjective. Who can say what is going on in their heads? Not me certainly but I am sure that because of the way they are done they are fairly meaningless.
It would actually be very simple for WHiFi to prove their claims. Record the signal coming out of the amp with and without the conditioner in place. Then use a comparator to show the difference in the signals. That wouldn't cost much, they could probably borrow the kit, Why don't they do it? Simple answer is that there isn't any difference and once that is exposed the whole edifice comes crashing down.
Chris
You need to try one my friend rather than just quoting the usual 'it can't possibly work' spiel
There are places you can return if not satisfied.
I have two and the differences are audible. Until you have at least tried one your opinion holds little water. If, after you had one in your system, you still feel it makes no difference ... I respect your view.
I have had Tacimas for some years, with varying results, mostly positive (as mentioned in my OP) but on the whole, it really is a fantastic, cheap and useful addition to many peoples systems.
C'mon Covenanter, live 'dangerously' and have a go ;-)
Happy Sunday everyone x
