System upgrade
And then there's these SABA 1240's for 665 euros or less. They are smaller than the Dynaudio Focus 260's. They don't have a bass-spoiling port and they are designed to be used against the wall...
https://www.ebay.de/itm/Saba-ULTRA-1240-Lautsprecher-Top-Generaluberholt-Yamaha-und-Isophon-geschlagen/153010583403?hash=item23a024376b:g:VYwAAOSwZKBZJKOp
https://www.ebay.de/itm/Nr-6893-2-Stuck-HIFI-Lautprecher-Boxen-Box-SABA-ULTRA-1240/372289287178?hash=item56ae2bb40a:g:KYgAAOSwAu5a4vzt
Wolf75 said:
Those JBL’s are rather big, and the room is a living room, so these are not an ideal option for me. I can pull the speakers 50 cm from the rear wall, listening distance is about 4 m, at the opposite wall. The room is 22m2. I listen a wide range of music, from rock to classical, jazz, blues, female vocals etc... The Devialet is a very likeable amp, but the price too high, don’t you think, it would be overkill for the Focus 260?
I think, without exception in the last while.....all those who have upgraded to an amp that might be considered overkill for their speakers, have been amazed at the performance it got out of them. A double upgrade, if you like.
The only person who can decide whether the outlay is worth it, is you. The reason I mentioned it, was that it has a built in DAC and it may well give a sound you are looking for (Clean/Dynamic/Punchy/Exciting/Musical)....and your speakers are listed as SAM ready.....but if it's more than you want to spend, than it should be ruled out.
...and if you are looking to buy an amplifier, 900 euros will get you this spiffy SAE X-15A:
https://www.ebay.de/itm/SAE-X-15a-150x2-W-Hypersonic-CLASS-A-TOP-USA-XXX-RARE-VINTAGE-RIBASSATO-OTTIMO/142771070336?hash=item213dd1a580:g:rWsAAOSwvGlagvgP
Half a million yen when new and 19 kgs.
