Suggestion pls-Wireless headphones for watching HD movies
Looking for a wireless headphones mainly to use while watching movies(HD,Blu-ray),come across Sennheiser RS-170,but some guys says its not really worth for watching HD movies!!!Any suggestion and advise welcome..pls
Olli1324
48
What kind of budget do you have? The Sennheiser PXC 310 BT headphones are £260 and are certainly worth considering. The RS 180s also review very well.
Thank's for reply Olli,My budget around 500 pounds,Regarding Senheiser Rs-180 ,i think its mainly for music (again ,opend back too-sound will also leak)and not having the surround sound capabilities!!!!I will check the other model which u have suggested to me,thanks
Sizzers said:
Do they HAVE to be wireless and closed back?
Looking for wireless,don't mind about closed back or open..if there s not much option for wireless pls recommend about wired too..thank's
Please ignore this is a test
/sites/whathifi.com/files/images/1001%20HiFi_0.jpg
Hi there!
I own a pair of Sennheiser MM550 Wireless Noise Cancelling and the're just great. I do watch HD movies with them and i have to i'm totally satisfied with the sound depth and quality. I got them form iHeadphones, go ahead and check them they've got plently of variant for wireless headphones you seek for
