Hello
I have an active sub added to my bookshelves speakers connected thru the high level output of the amplifier ( aka the speakers output) . Works fine , it changed the sound ,added just a bit of bass where I needed . I cut the frequency at about 75-80 HZ and the Volume at about 35%.
I Want to change and make some upgrades of the system with minimum cost . For the beginning I want to buy another sub ( same brand and type) and use in stereo configuration .I hope it would enhance the stereo imaging and the accuracy of low frequencies .
In the same time , I want to try to connect the subs in a different manner , using the PRE OUT output of my Consonance A100 linear amp ( it desn't have a dedicated subwoofer output).
So , I think I should use two subwoofer dedicated RCA-RCA sub cables , one for the left and other for the right Pre output , ending each at one sub . But at the subwoofer end this cable should be connected only one or to both input RCA ( red and white , using a Y splitter ) ?
