Subdude. Yes or No
got mine today it has tightened up the bass no end more defined and you can hear the notes . If anything it sounds leaner but thats because everythings not rattling anymore
. I would say go for it mine is sat on a concrete slab with carpet on-top and it has made a great and good difference.
tris
I would suggest a Gramma instead , slightly bigger and cheaper.
But if you buy any of them you might be disappointed when you see what you get for the money
Consider making your own
It was £62 delivered from a well know music retailer I use for my keyboard addiction. I would have gone for the gamma but im limited by room and the subdude was a perfect size for my sub. the more I listen the more I like it. I use a gamma fot the sub attached to the keyboard as some of the soft and hardware i use can go low and loud and it helps keep vibrations down but I mix on headphones its a strange world.
