davedotco said:Beware, it is not quite that straightforward.
IME. This statement appllies to most things hifi, despite what some people may say.
inbox4 said:My experience of streaming with my MacBook Air has been the definition of simplicity. The first time I ever connected the computer I selected my DAC in the audio output settings and set the '2ch - 24 bit Integer' to 192000.0 Hz. That was it. I've never had to do it since. These settings have been retained and it sounds great!
Can anyone explain how with these settings I wouldn't be getting a bit perfect stream to my DAC and what benefit BItPerfect software would offer?
TimothyRias said:With those settings you will only get a bit-perfect stream if the file played back is 2 channel/24bit/192kHz. For anything else the system will remix/resample it resulting in a bit-stream that does not exactly match the the source file.
inbox4 said:What settings would you recommend for a bit perfect stream of Spotify (Premium)?
cheeseboy said:TimothyRias said:With those settings you will only get a bit-perfect stream if the file played back is 2 channel/24bit/192kHz. For anything else the system will remix/resample it resulting in a bit-stream that does not exactly match the the source file.
depends on the soundcard or dac you use as well. If it supports 24bit 192khz it won't have to re-sample.
TimothyRias said:cheeseboy said:TimothyRias said:With those settings you will only get a bit-perfect stream if the file played back is 2 channel/24bit/192kHz. For anything else the system will remix/resample it resulting in a bit-stream that does not exactly match the the source file.
Not sure how a you view a soundcard outputting a 44.1kHz file at 192kHz without resampling. (You probably misread what I said.)
TimothyRias said:inbox4 said:My experience of streaming with my MacBook Air has been the definition of simplicity. The first time I ever connected the computer I selected my DAC in the audio output settings and set the '2ch - 24 bit Integer' to 192000.0 Hz. That was it. I've never had to do it since. These settings have been retained and it sounds great!
Is this bad?
Not necessarily. With decent interpolation resampling, from 44.1 kHz (CD quality) to 192 kHz should give quite good results. I would be very surprised if anyone could pick out the difference. (And if they can, it is not unimaginable that the upsampled stream sounds slightly better due to smoothing out digitization artifacts in the source.)
The more problematic case of resampling is where (as in many machines by default) a 44.1 kHz stream is resampled to 48 kHz, which can lead to audible conversion artifacts. (especially with high speed interpolators that trade quality for speed).
inbox4 said:TimothyRias - thank you very much, that makes perfect sense. I had wrongly assumed that the setting meant the computer would correctly play anything up to 192KHz files. What settings would you recommend for a bit perfect stream of Spotify (Premium)? Everyone - what are the best sounding 24/192 albums in your experiences? I was reading about it at the weekend and it seems dynamic range/ sound quality varies as much if not more in this format than others. I would like to find an absolutely cracker of a recording just to hear how good things can sound when the stars align and everything is mastered perfectly etc...
the record spot said:inbox4 said:TimothyRias - thank you very much, that makes perfect sense. I had wrongly assumed that the setting meant the computer would correctly play anything up to 192KHz files. What settings would you recommend for a bit perfect stream of Spotify (Premium)? Everyone - what are the best sounding 24/192 albums in your experiences? I was reading about it at the weekend and it seems dynamic range/ sound quality varies as much if not more in this format than others. I would like to find an absolutely cracker of a recording just to hear how good things can sound when the stars align and everything is mastered perfectly etc...
Be sure, if you can, to compare the same mastering, else you're just comparing apples and oranges.
inbox4 said:the record spot said:inbox4 said:TimothyRias - thank you very much, that makes perfect sense. I had wrongly assumed that the setting meant the computer would correctly play anything up to 192KHz files. What settings would you recommend for a bit perfect stream of Spotify (Premium)? Everyone - what are the best sounding 24/192 albums in your experiences? I was reading about it at the weekend and it seems dynamic range/ sound quality varies as much if not more in this format than others. I would like to find an absolutely cracker of a recording just to hear how good things can sound when the stars align and everything is mastered perfectly etc...
I'm not sure what you mean? Are you suggesting the sample rate Spotify streams at isn't consistent?
inbox4 said:Following the useful lesson above, can anyone confirm the setting I should choose on my Mac for a bit perfect output of Spotify Premium (via USB to async DAC)?
Would it be 44.1Khz?
Craig M. said:inbox4 said:Following the useful lesson above, can anyone confirm the setting I should choose on my Mac for a bit perfect output of Spotify Premium (via USB to async DAC)?
Spotify premium streams at 320kbps (I think), no matter what you set your Macs output at it is going to be converted. There isn't a 'bit perfect' in this case. As the record spot has said, the quality of mastering is what's important regards sound quality. More important even then the kit you're listening to it through.
Craig M. said:[...]
