inbox4 said:Original post should have read...
I can’t help but think I'm missing something....
I've been reading Linn's and Cyrus' web sites to learn more about their respective streamers.
Currently I connect a MacBook Air via USB to an async DAC. This obviously allows me to play Spotify and my iTunes library etc and it sounds great.
I can't see what extra a dedicated streamer would offer?
Surely a laptop connected to a DAC (via async USB) is a very similar solution and generally cheaper (assuming you already own the DAC)
Am I missing the point?
I'd be interested to hear different views....
inbox4 said:Am I missing the point?
iMark said:We find the Airport Express very useful. My Mac Mini, with the iTunes library is in another room. We can use the iPad as a remote control for the iTunes library or stream Spotify directly to the Airport Express. My ripped CDs sound better than any of my previous CD players.
In our previous house I had the computer in the same room as the stereo and had it connected with long RCA cables. Not a very good solution and it caused all sorts of ground loop problems.
I definetly recommend getting some sort of streamer if you have music library on a computer.
cheeseboy said:inbox4 said:Am I missing the point?
no, you're not missing the point. A streamer is basically a computer, probably running a version of linux in a box without all the keyboard and mouse gubbins and only does one thing.
Some people have computers that sound like jet enginges when they turn them on, so it's understandable they don't want them running to listen to music. For some people it's conceptual barrier - ie computers don't play music, that's what stereos do. For others they may use both, for some it's costs etc. It just all depends on what you want and how you want to do it.
jerry klinger said:But the bit of the streamer that makes the difference sound quality wise is the DAC anyway - witness the number of Naim users who first buy a £3000 streamer and then feel the need to add a £2000 DAC (plus a £3-6000 power supply). To me a typical streamer is an internet tuner which can also get music from file storage which I don't actually have. If I want to play music on computer I'd plug a laptop into a DAC. The internet tuner bit is usually well-implemented with vTuner and thus easier to use than a puter but that's about it. Expensive streamers = large white elephants. I've owned a couple and have often felt 'what's the point?'
CnoEvil said:jerry klinger said:But the bit of the streamer that makes the difference sound quality wise is the DAC anyway - witness the number of Naim users who first buy a £3000 streamer and then feel the need to add a £2000 DAC (plus a £3-6000 power supply). To me a typical streamer is an internet tuner which can also get music from file storage which I don't actually have. If I want to play music on computer I'd plug a laptop into a DAC. The internet tuner bit is usually well-implemented with vTuner and thus easier to use than a puter but that's about it. Expensive streamers = large white elephants. I've owned a couple and have often felt 'what's the point?'
IME. A streamer is the sum of its design, including quality of power supply; clocking, how well upsampling is handled; order / quality of noise filters / shapers etc. Get this right, and the streamer will more than hold its own.
inbox4 said:@ CnoEvil - it was reading your previous posts and enthusiasm for Linn streamers that pricked my interest today and led me to their web site and to start this thread.
inbox4 said:CnoEvil said:jerry klinger said:But the bit of the streamer that makes the difference sound quality wise is the DAC anyway - witness the number of Naim users who first buy a £3000 streamer and then feel the need to add a £2000 DAC (plus a £3-6000 power supply). To me a typical streamer is an internet tuner which can also get music from file storage which I don't actually have. If I want to play music on computer I'd plug a laptop into a DAC. The internet tuner bit is usually well-implemented with vTuner and thus easier to use than a puter but that's about it. Expensive streamers = large white elephants. I've owned a couple and have often felt 'what's the point?'
Are a lot of things you mentioned not handled by the DAC, especailly when connecting via USB as the DAC syncs the clocks both ends?
CnoEvil said:IME. A streamer is the sum of its design, including quality of power supply; clocking, how well upsampling is handled; order / quality of noise filters / shapers etc. Get this right, and the streamer will more than hold its own.
p_m_brown said:I'd be up for checking out a Linn DS to see how it fairs against my Sonos and Leema dac which btw, sounds superb with the coaxial output!
steve_1979 said:CnoEvil said:IME. A streamer is the sum of its design, including quality of power supply; clocking, how well upsampling is handled; order / quality of noise filters / shapers etc. Get this right, and the streamer will more than hold its own.
How is it possible to improve on any hifi streamer or computer that can output a BIT PERFECT data stream to an external DAC?
It's already BIT PERFECT (the clue's in the name BTW).
