Stopping fan from causing noise
alienmango
21
Hi everyone this is my situation:
I have a cheap pro-amp I poached from ebay which puts out 600w rms, I use it to power a subwoofer in my bedroom (normally) and I only use a few watts (under 100) 99% of the time for normal listening.
Would it be safe to obstruct the fan with a stick to stop it making noise when it's only on low or could it damage the amp in some way? the fan noise is obtrusive at low levels.
Thanks.
Overdose
279
Thanks.
Do you think that sounds like a good idea?
RobinKidderminster
582
Is he serious??? Swap the fan. Disconnect from mains first. Keep all components away from water. Wear industrial globes and thick rubber boots, fireproof jacket and welding mask
alienmango
21
Thanks.
Well basically no BUT .... if it's only outputting 10 watts it's hardly likely to output much heat is it. :cheers:
I understand is your reaction is this.... :wall:
Al ears
Thanks.
Perhaps you might consider why they bothered fitting it with a fan in the first instance.
Heat does not necessarily depend on the volume control position. :)
Wattage doesn't matter either. I know some 10 watt Class A ampsthat make a very nice room heater.
cheeseboy
245
Thanks.
don't do anything with the fan. If it's too noisey, try getting a replacement silent fan from cpc or Rs/farnell type place.
Electro
192
Why not have the noisy fan replaced with one of these quiet fans , it should not cost much and it won't burn your house down :)
http://www.quietpc.com/casefans
alienmango
21
"Perhaps you might consider why they bothered fitting it with a fan in the first instance."
Well it's designed to be run at full volume (and even slightly into clipping) for hours on end with no problems...hence the fan. How likely is it really that a 600wrms amp is class A (given that it's also a pro amp) ???
Will fit a new fan, thanks for the recommendation.
Thompsonuxb
125
try placing the amp on two squash balls cut in half.
the sound of the amps fan maybe made lowder by were you have the amp seated - glass surface, cupboard etc. the rubber of the squash balls will dampen/absorb any excess vibration/noise output by the fan.
oh and no... the spot makes no difference.
