OK - I know there are a lot of different opinions here - so I will make my question quite specific...
I'm looking at getting some music by - STEVIE RAY VAUGHAN
If you are a fan can you suggest if I should buy
an original LP from e-bay?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350229141173&ssPageName=STRK:MEWAX:IT
A modern LP from HMV?
http://hmv.com/hmvweb/displayProductDetails.do?ctx=280;-1;-1;-1;-1&sku=415465
Or a remastered CD from HMV?
http://hmv.com/hmvweb/displayProductDetails.do?ctx=280;-1;-1;-1;-1&sku=796162
You can see from my list below what kit I'll be playing it on - since upgrading the cartridge I've been very impressed with the Ortofon OM 10 on the Project deck - and for me it sounds better than the NAD CD player
But what do you folks think?
Thanks for your input.
