Stands for KEF R100 speakers - help please!!
Ijster
I have a pair of KEF R100 speakers on order and need some stands. I feel rather in the dark as to what I should be looking for.... any suggestions gratefully received!!
You just need any stands from a reputable manufacturer that lifts your speaker so that it's tweeter is approximately level with your ears when you are in your norml seated listening position.
Atacama Nexus 6i should be about right check height for your listening position, tweeter should be around ear level. These come up on ebay quite often for around £20 so I would have a search, new they are about £70. Custom Design are good but a bit more expensive.
Think about the colour as well.
I use nexus 6, does the job and the silver ones really look the part with piano black speakers!
+1 with the Atacama Nexus 6. I use them with my R100s filled with the metal arbitrate stuff. I have them in satin black and all looks pretty good to me!
Thank you all very much for your suggestions and advice! I'm going to order some Custom Design sq402s in oak. 🙂
