...or E-Bay:
Find many great new & used options and get the best deals for Hi-Fi Stereo Sound Balanced Connector Auxiliary Plug Splitter Support Converter at the best online prices at eBay! Free delivery for many products.
www.ebay.co.uk
...says it 'can improve the sound quality of transmission'
Make sure you select the correct one in the pull-down box, as they do 4 different types.
When I Iooked, the one you want was one of the only two they had in stock, £11.82.
Although you may be better off going for one of those with a cable - otherwise, with the above type, once you go into an additional 6.35 to 3.5mm adaptor, it's starting to get silly (too much leverage waiting to break the plug off).
To do what you're after, I just bunged one of these onto the end of a TRS cut-off 3-core cable:
Find many great new & used options and get the best deals for 1PCS 4.4mm 5Pole Headphone Plug Adapter For Sony NW-WM1Z Female Converter Black at the best online prices at eBay! Free delivery for many products.
www.ebay.co.uk
