David , while there's a interlude...mmmdavidf said:I like them.
Mmmmmm 🙂alchemist 1 said:David , while there's a interlude...mmmdavidf said:I like them.
How good is that Technics SL -1000R ....
CnoEvil said:I tried listening to my system without speakers (I don't have headphones).....it was pleasantly tranquil and everything sounded the same - but it's much better with them connected.
It's an Actively In-Active system.jjbomber said:CnoEvil said:I tried listening to my system without speakers (I don't have headphones).....it was pleasantly tranquil and everything sounded the same - but it's much better with them connected.
Is this what audiophiles mean by an in-active system?
CnoEvil said:It's an Actively In-Active system.jjbomber said:Is this what audiophiles mean by an in-active system?
It has many advantages, as all Mastering sounds the same and expensive cables / Isolation products / Power supply upgrades, make no difference. What's not to like. I've even blind ABX and Double Deaf tested it all, as well.
jjbomber said:CnoEvil said:It's an Actively In-Active system.jjbomber said:Is this what audiophiles mean by an in-active system?
Is it the same with Cr-Apple? If you don't switch them on, there aren't any compatability problems.
Infiniteloop said:jjbomber said:Is it the same with Cr-Apple? If you don't switch them on, there aren't any compatability problems.
I've used Apple products for over 20 years and never had any 'compatability' (or other) problems.
jjbomber said:Infiniteloop said:jjbomber said:Is it the same with Cr-Apple? If you don't switch them on, there aren't any compatability problems.
Try switching them on!!!
