- Aug 10, 2019
- 2,556
- 5
- 0
My current system consists of the following:
NaiM CDX CD payer; Naim NAC82 Pre-Amp with HI-CAP; Naim NAP250 Power-Amp; Monitor Audio Studio 12 Speakers
and I wish to replace the speakers to improve the system. The room that the system is in is approx 3m square and the speakers will have to stand between and close to adjacent furniture, so they will have not to require much space around them. The speekers can be either close to or reasonably away from the rear wall.
I had heard that Wilson Benesche Arc speakers work well with my set-up and hence I was considering them , but I am also wondering whether Pro Ac DA28 speakers may be appropriate; I would appreciate your thoughts on the suitability of these and on what you might otherwise recommend; I am happy to buy new or used speakers. My preference would be on a combination that produced a well balanced sound that captured the beauty and balance of the music. I like a range of music types, including rock, pop & classical.
Regards
Peter Harris
Regards
Peter Harris
