Speakers to match Rega Brio-R + Rega DAC-R
CnoEvil
556
14
You could try Rega's own speakers along with Q Acoustics Concept 20 and Kef R100/LS50s....you didn't give a budget or room size.
CnoEvil
556
14
shy10ck said:
Room size 14m2
Budget: Whats resonable compared to the price of the Rega Brio-R. Maybe 800€ a pair.
Given your room size, the Standmounts I've listed should be fine....you need to hear what different budgets will achieve, as the Rega RX1 and LS50s are a bit over €800, whereas the Kef R100 and Concept 20s are not.
CnoEvil
556
14
shy10ck said:
Cant find any reviews of Rega RX1, but maybe a bit to expensive anyhow.
You might still find the previous model about, which is substantially less costly (and less good).
I was very impressed by the Concept 20s when I heard them.
radiorog
149
21
18,595
+1 focal aria 906
You'll likelywant an efficient to drive speaker which the focals are. I had a brio r with my dynaudio, and they sounded very good, but I expect the focals might sound even better.
shy10ck
Thanks all. I am reading and looking at your suggestions.
Question: Should I choose 4ohm or 8ohm speakers to the Rega Brio-R?
Rega Brio R specs:
50w RMS pc into 8 ohms 73w RMS pc into 4 ohms[/list]
iceman16
Rega Brio R specs:
  • 50w RMS pc into 8 ohms
  • 73w RMS pc into 4 ohms
The Focal 906 are fairly easy to drive with (specs) 89.5db sensitivity and 4.6ohm minimum impedance. IMO they are less forward sounding speakers Focal have made.
shy10ck
I have decided to go the other way around and start with the speakers, instead of the Amp.
Thanks for all your inputs, they have inlightened me.
I will start a new post. Hope you will join in.
I suggest you consider the amp and speakers as a system, in the sense that they will influence each other. Buying great sounding speakers and spoiling them with an inferior amplifier will lead to disappointment. Conversely, a fine amp will make the best of even modest speakers.
