Speakers matching with Naim Nait 5i in my room
Joël Verheyen said:
Okay, so buy some good stands does the trick. What stands did you buy?
I bought the Custom Design F104 and some mass loading material similar to Atabites but a fraction of the cost. Two thirds filled each central column.
But any stand that is rigid enough not to move backwards and forwards when the volume is higher. I found the bass started rocking the old stand and then the bass lost focus as a consequence.
iceman16 said:
You can try Atacama Nexus speaker stands and fill them with sand or atabites. I use them with my LS50s and they sound really good. I also use some blutak between speakers and stand.
That was the stands I ditched. Nexus 6 but they were about 10 years old. I just couldn't tighten the nuts tight enough to stop the thing rocking back and forwards.
plastic penguin said:
Joël Verheyen said:
Hi guys
I have a Naim Nait 5i amplifier, laptop connected via usb with a Rega Dac, and a pair of monitor audio silver rx6.My setup is looking like the picture (7m x 4m):I don't like the combi of the monitor audio's and the amp, so i'm selling my speakers. The sound is to bright for me, not enough body, sounds flat, ...
The question: what speakers would you recommend for the Naim Nait 5i in the room I live. It's not possible to rotate my setup (I know it would be better), but that's not possible (windows / doors).
Joël
Not surprised. I've owned the RS6s and really loved, but paired with Naim is a NO NO. If you don't mind s/hand then PMC GB1is will fit the bill beautifully. Although a floorstander, they are compact and their ATL is front firing, which makes them a little easier to place.
Neat Motive 2 should also hit the spot, as will Dynaudio standmounters.
Good call on the PMCs. I've listened to the SN2 driving various different PMC models, and it sounded pretty damn good!
