On several occassions participants mentioned a possibility of upgrading Naim Unity, either by bi-amping and/or adding Naim power supplies. As Naim is now locally slightly more expensive than in UK (as well as Spendor, Proac, PMC and Neat) and meets most of my requirements:
What would be the max upgrade level on the Unity for gains to make sense, financially and in terms of audible sonic improvement (i.e. instead of buying separates for similar amount)? Taking into account some benefit from a one-box, no-cables solution ......
What speakers should be used then, the ones listed in this thread or models higher up the line (so, not PMC GB1i, but FB1i; not A5, but A6 etc.).
My speakers are still AE 109 (should suit Naim for some time), and Unity would leave me enough upgrade options later on.
Naim + Spendor/Proac are available in one shop locally, Naim + Spendor/Neat in another one close to my home, PMCs are in a different shop, difficult, but not impossible to audition with Naim. I could audition Naim with AE109 in the shop (and probably at home).
Thxs. for your suggestions,
postup
