I have bought a Denon AVR X-3600H and a set of Focal 5.1 SIB EVO Speakers. I will be wiring them all up soon. I will have to run both the rear speaker wires around the same side of the room.
I have a couple of questions before I start:
1. Is it ok to zip tie the two speaker Cables together?
2. Do I need to make both cables the same length?
3. If I do then the rear left cable will be about 15 feet longer than the right...is it ok to coil the wire up to make it tidier?
Thanks in advance.
Davva
Thanks in advance.
Davva
