Speaker termination
vpacalypse
151
Educate me in cable termination
What desired effects does it produce over simple wiring?
I run chord company carnival silverscreen. These run off to MA BX2,
Termination worth buying?
scene
789
187
19,070
The main advantages of cable termination are guaranteeing that you get a good solid connection between the cable and the amp. If you're using bare cable, and (say) binding posts, the risk is that oxidation on the cable, grease from your fingers, etc. may reduce the quality of the signal. Now you can avoid this by cutting a fresh cable end, and cleaning the cables and binding posts with (say) acetone.
NB: You should ensure your amp is unplugged and wait for the acetone to dry properly in a well ventilated room to avoid any fire risk...
The issue is over time, the cable can still oxidise, but you can repeat the process bi-annually. You should also do this if you ever unplug the speakers.
If you cut and clean the cables and then solder them into gold-plated banana plugs, then you avoid this issue.
Airloc ones from Chord are very good also.
