speaker positioning
hi
ive got the monitor br2 av package but today bought a pr of br1's, i would like adivice on where to position them at the moment i have bi-wired the pr of br2's and using them as front l+r and the brfx's as rears.would i be better moving the brfx's to side l+r and using the br1's as rears or just putting them as front height speakers...? oh and im currently searching high and low for a pr of either br5's or 6's in walnut to use as front l+r which will free up the br2's advice would be much appriecated
rob
lg 37" onkyo tx-nr807 panasonic dmp-bd85 blue ray qed silver xt speaker cable all connected with cabridge audio series 900 hdmi bt vision ps3 monitor audio br1's br2's br-fx's br-lcr and br-w10 sub
audioaffair
100
Hi, what size and dimensions is the room? Sometimes there is no substitute for trial and error - you could try moving things around and compare the same snippet of movie soundtrack to see what you think of the difference.
Frank Harvey
567
Depending on your room layout, the general rule of thumb is to have the direct firing BR1's as rear centre speakers, and the dipole BRFX's on the side walls so they can fire up and do the room (to recreate the multiple 'rear' speakers down the sides of a cinema).
