Speaker for the Sony STR DA 2400ES
• Analyzing all the the forum’s colegues information and the WHF reviewes have provided to me , I ‘ve changed my last home cinema decision (very influenced by the sellers I’ve been speaking with).
I ve chosen the Sony STR DA 2400 ES as my AV receiver (good functionality and very recommended for musical use ) and now I have to decide the 5.1 speaker package wich complete the set up. This are my options:
Qacoustic 1010i , they appears like the favourites.
Jamo A102HCS5. Some threads don´t recommend the combination sony/Jamo A102 because the sound is very bright.
Jamo A405HCS5 . The WHF analisys recommend other options before these. Tannoy HTS100. I have not seen a WHF review of these.
Tannoy HTS200 I have not seen a WHF review of these. Mordant Shord Premier I have not seen a WHF review of these.
What do you think will be the best speaker for the sony if I’ll use the receiver 50% for HomeCinema and 50% for Music (the musical feature is important for me)?
Thank you for your advise
spfrank:
Analyzing all the the forum's colegues information and the WHF reviewes have provided to me , I 've changed my last home cinema decision (very influenced by the sellers I've been speaking with).
Jamo A102HCS5. Some threads donït recommend the combination sony/Jamo A102 because the sound is very bright.
What do you think will be the best speaker for the sony if I'll use the receiver 50% for HomeCinema and 50% for Music (the musical feature is important for me)?
Q Acoustics all day long.
I have the Q Acoustics attached to my Sony 2400es and the sound is quality running blu-ray from sony 350 blu ray player.
I have the Q acoustics (replaced 1010i fronts for 1030i) attached to the Onkyo 606.
They are good speakers and not overly bright (like the Sony can be?), but with quite a neutral, detailed sound, so they should compliment each other well.
I would imagine you would need to avoid the sony 2400es with something like the KEF 2005.....both being on the bright side??? (But I may stand corrected by someone on here!!)
Hope that helps......
Thank you for your information:
Can you tell me how is your Sony - Qacoustic configuration playing music ?
I make a lot of questions because in my town is very dificult (impossible) to get and auditioning of this set up.
Thank you for your help Forum .
