Speaker cable upgrade
Hi. I am planning to order a qed silver anniversary xt biwire cable to replace my 69p per meter gail symphony speaker cable. Although I am only using the MS 900i series with MS908i as fronts hooked to my Onkyo 606, I am already satisfied with my current set-up. With this upgrade will I notice any significant improvement on my system's performance? Thanks.
IMO you would be better off with Chord SS. They offer different qualities but with your set up the Chord will sit better.
And with the Chord especially, you'll hear a significant increase in performance (as cables go).
Can somebody share their experiences regarding speaker cable upgrade? Did you start building your system using a budget speaker cable then upgraded it to mid-priced and heared the difference? Is it really worth the upgrade? Thanks
