MajorFubar
- Mar 3, 2010
- 690
- 12
- 0
Speaker cables can't burn in. Common-sense should tell you that, even if your ears deceive. What electrical property exactly do you think is changing over time?
BigH said:Send them back, 100 hour run-in is rubbish thats just to discourage folk from returning them.
Tommo2 said:I have owned cable talk 3 for c.18yrs.
Recently upgraded my system to Yam 2010, MA rx6av, Chord Odyssey 4 & 2. Have read for many hrs about upgrading cable. Some say won't make any difference some say it will. Some say don't use silver plated cables with MA use copper. Some have upgraded to Odyssey 4, 2 and said it improved the sound on many different set ups but it may need time to run in. Even some reputable advertisors on this site who own their own shop have recommended this cable with my set up. I thought what the hell I'll sell it on ebay if it's worse than cable talk 3.
I have wired up my front speakers bi-amped one with Odyssey 4 and the other has cable talk 3. Chord say 100 hrs to run in (from memory I think), mine has been on 1 hr.
Emile Sande cd - rewinding the cd back and forth as I listen to one speaker and then the other over identical parts of a track I can say the Odyssey sounds identical to the cheaper copper cable talk 3. To my ears Odyssey doesn't sound harsh with my MA front 6's, tone, voices, instruments etc sound identical on both cables imo so far.
Now when it has run in if Odyssey 4 doesn't sound better than the cheaper, much cheaper cable talk 3 I won't be very happy as I have just shelled out nigh on £300. Time will tell.
ellisdj said:You need to have them both wired up for starters then listen to the complete image - secondly if your speakers have metal inbetween the binding posts high freq and low freq that should be changed as well to the wire you are using.
Thats should be the rule of thumb for all speaker cables whether twin and earth or Valhalla
The bits of included metal make speakers sound terrible, worse than terrible in fact and I am yet to hear different. It normally affects the part of the speaker thats not wired into - i.e. wire into the tweeter the vocal will be metallic - wire into the low bidning posts and the treble is metallic. It will also make a difference if you wire into the high freq posts or the low posts.
