Speaker cable lengths?
Pistol Pete1
248
Does it make much difference if one length of cable to a front speaker is longer than the other?
I have my Onkyo 606 on the left side of the rack, and it needs a 2 metre cable to the right speakers, but obly a metre one to the left side. Is doing that going to affect the sound?
Will be using the Chord Silverscreen. Is it as good when ordered as a biwire cable, as it is as a single cable?
My understanding is that no it doesn't make a difference. The speed of light is pretty quick so a couple of metres won't make a difference. When I get around to buying a matching power amp, I'll buy a pair of shorter cables to go with my 3m pair for the near side speaker.
idc
1,142
117
19,370
It is one of those areas where there should not be a difference, but some find there is a difference. Clearly, if have heard an old fashioned tannoy at a football ground blasting out music the cable lenght does matter. But at 1 to 2 meters this will be less so. Unless you are buying very expensive cable I would say get equal lengths just to give you future flexibility if you move the system/furniture/house.
Gerrardasnails
295
Pistol Pete1:
No one would notice a difference with those lengths of cables. Mine are 2.5m and about 1.75m. They could be 7.5m and 2m and it wouldn't make a difference.
Big Chris
400
Big Aura:Gerrardasnails:
I could. But I'm special needs.
laserman16
99
Big Chris:Big Aura:Gerrardasnails: No one would notice a difference with those lengths of cables. I could. But I'm special needs. ;-)
laserman16
99
laserman16:
Big Aura
522
10
18,895
Fecker! I've been in the pub all afternoon (team building!), and I come back to that? Breaks me auld Oirish heart....
PS - Laserman get the super-speshul award for double-posting.
Pistol Pete1
248
Thanks for all the banter on this post.......
But is the biwire version as good as the single version of the Chord Silverscreen cable?
