We use , recommend and sell basic 79 strand and basic 500 strand speaker cables. Our advise is to save your money.Hi everyone
Keen to hear you're recommendations on speaker cable? I have just bought some PMC twenty5 24 speakers, paired with a Moon 240i.
Let me know your thoughts?
Paul
Two camps regarding speaker cables: those who say that cables make a difference and those who don't. I'm with Musicraft and Abacus - a non-believer of the requirement for special exotic cables. Think you may find that even PMC state that as long as it is of sufficient gauge then any cable will do.
I've tried several different types of banana plugs and can highly recommend these.I got my XT40 for less than £5 pr meter, some day i got try it again but it didn't connect that well with my plugs some ends lost connections and made som kind of noise because of that, think it was the cambrigde banana plugs
Don't let the naff little logo put you off, these are high quality, excellent value plugs.
The two offset grub screws leave you feeling confident about the termination:
You want right angled? You've got right angled:Fisual Easy Fix Banana Plugs 24K Gold Plated: Amazon.co.uk: Electronics
Shop Fisual Easy Fix Banana Plugs 24K Gold Plated (8 Pack). Free delivery and returns on eligible orders.www.amazon.co.uk
Fisual Easy Fix 90 Degree Banana Plugs 24K Gold Plated: Amazon.co.uk: Electronics
Shop Fisual Easy Fix 90 Degree Banana Plugs 24K Gold Plated (4 Pack). Free delivery and returns on eligible orders.www.amazon.co.uk
Rather spend that kind of cash on music or another piece of kit... not cables or rhodium plated plugs. Your money, your choice; my money, my choicerhodium plugs that are better than gold plugs can be expensive, so for a high end system £500 isn't to bad
Why?I've only skimmed the thread. Anyone asked OP about the length?
If OP wants a fancy cable it would be worth knowing if it's 10m at £50 pm or 1m at £500 pm that he's looking for suggestions forWhy?
Quite agree it might be nice to know if he has a budget for these cables ....but he seems simply wanting to know people's thoughts on them, the way most cable threads go. I notice he hasn't bothered to come back with any feedbackIf OP wants a fancy cable it would be worth knowing if it's 10m at £50 pm or 1m at £500 pm that he's looking for suggestions for
Seeing as PMC advice in there own manuals is that expensive cables are a waste i'd follow there advise. I use linn k20 through out all the systems ive had and to be honest ive found nothing that can better there "sound" when i have been a bit a curious too see if anything can make a difference.Hi everyone
Paul
You've found nothing that can better Linn k20, but was anything you tried actually worse? If not, maybe you paid more than you needed to with the k20.Seeing as PMC advice in there own manuals is that expensive cables are a waste i'd follow there advise. I use linn k20 through out all the systems ive had and to be honest ive found nothing that can better there "sound" when i have been a bit a curious too see if anything can make a difference.
