Speaker cable for new system
peddie44
19
Hi all I need to order some speaker cable to go with Sony STR-DH810 and Boston Acoustics xs, obviously don't want to spend a fortune on cable if I can avoid it. Can anyone recommend what / where to buy? Thanks
I got mine from ebay... £5 for 10m... I'll post a link when I'm on my PC and can find my password if you would like it.
Sounds fine to me!
peddie44:Hi all
Hi peddie44
I'll suggest popping down to your local electrical store and getting some standard 79 strand OFC speaker cable. This cable will be more then good enough for your system.
All the best
Rick @ Musicraft
MUSICRAFT:
peddie44:Hi all
Hi peddie44
All the best
Rick @ Musicraft
I agree with rick,I'm in the process of replacing my atlas hyper 3.0 cable with the same cable.
Here is what I used. Although I would love to hear what expensive cable sounds like, this will do me fine for now 🙂
Pikman:
I've used this myself and they are excellent value for the money.
Ronald Archiebald:Pikman:
Yep same here just set up a MA system with it superb value for money wish i'd known about this before I bought all my QED anniversary XT cable.
Hi all,
I am too in the process of buying speaker cable. Was going to get either Chord/QED/Van Damme but might just change my mind now based on this thread!
Just a couple of questions:
1) As long as the cable is 79 strand or above and OFC then it will suffice?
2) Looked at the link for the cable that was posted its 2.5mm. would it be better to get 4mm cable as most people have suggested?
Thanks in advance
The chord silverscreen is a good value speaker cable for its price, better than the similar priced QED - more balanced tonally.
Steve.
Currently using 322 strand cable, cost me £5.50 from Ebay for 10m - Digitalis Direct I think was the seller. No issues with it. I tried it out on a whim, to give it a whirl really, and found it slightly better than the solid core Audioquest Type IV cable it replaced. Maybe something to do with it being multistrand copper...don't know the science at work here!
Always cut the red wire!:
Cheers Steve,
It was the Chord Co Carnival Silver Screen/QED Silver Anniv' XT Evo/Van Dammme Blue 2x4mm that I was looking at. Chord was £4.50/m and the others £3.25/m.
Just to clarify - I was talking about the chord carnival silverscreen and QED silver anniversary. I havent tried the Van Damme Blue. The chord is good cable for its price.
All the best
Steve
