spdif output confusion
Dave_
according to my device manager i have a spdif output on the right hand headphone jack of my laptop, trouble being i thought spdif was coaxial, but surely if its using a mini jack it would be a optical output like they are on mac's, or can you get a mini jack to rca digital coaxial interconnect, by the way the laptop in question is a dell inspiron 1525, theres no information about it either in the handbook, or in the tech specs or on dells website that i can find, any help would be appreciated
No, SPDIF is optical, and you need a mini-toslink-to-toslink cable.
I had a picture somewhere once, hang on.......
Here you go:
cheers andrew and jd, just heard back from dell, and apparently(just to be awkward) imo, it actually outputs via the s-video port, and you have to get an svideo to composite+spdif adaptor,
daveh75:cit actually outputs via the s-video port, and you have to get an svideo to composite+spdif adaptor,
Bizarre - and a new one on me!
Thing is, your device manager is telling you you have a digital out in the headphone socket, yes? I would be trying a mini toslink in there (if you have one to hand).
just looked in device manager again, it actually says spdif via right hand jack, think i assumed it was the right hand mini jack as i didn't know it could be ouput via s-video port,
hm no, might have just been references to it in dell manuals. Do you have an optical cable, even if is a toslink socket at either end? There are adapters to fit headphone-socket-style to toslink, which might be cheapest way to try it and see.
just found a reference to it in the dell manual on there site, and it definitely outputs via s-video, so i guess i'll have to get the adapter,or just not bother and use the mini-jack to rca lead i've been using, or wait till i get an a/v receiver and use the hdmi out
