They all sound the same mate thats what we are saying
Well only if you believe jitter doesn’t exist…..🙄Hang on, you’re saying that the optical cable in stock at my local Currys/PC World for £3.49 (1m length) works just as well as one priced at £49.99 with gold plated connections on sale in the same store?
OMG!!!
As first ever posts go, they don't come better 👍They all sound the same mate thats what we are saying
Well not quite…it’s the timing of the bits which matters……Life can be quite simple sometimes. With an optical cable you only need that the cable transports all the bits from one device to the other. If the cable does that, it works.
If only that were true….They all sound the same mate thats what we are saying
There are loads of people that would be willing to bet that, in a blind test, you couldn't consistently tell one optical cable from another.Well not quite…it’s the timing of the bits which matters……
All I know is I upgraded from a Van den Hul Optocoupler (£60) to a QED Performance Optical (£99) and not only did it sound clearer…it would pass 24/192 whereas the Van den Hul would only do 24/96…so not all cables are equal. Just my experience but you are free to disagree obviously 🙂There are loads of people that would be willing to bet that, in a blind test, you couldn't consistently tell one optical cable from another.
You could make a lot of money proving them wrong 🤔
Your bitrate example proves that there's a difference.All I know is I upgraded from a Van den Hul Optocoupler (£60) to a QED Performance Optical (£99) and not only did it sound clearer…it would pass 24/192 whereas the Van den Hul would only do 24/96…so not all cables are equal. Just my experience but you are free to disagree obviously 🙂
Yes and I'm sure the difference between their L & R ears might also shock some people(Many people consider themselves to have good hearing, but get a big shock when professionally tested, as in most cases it turns out to be not as good as they thought it was)
Bill
Maybe post them on Hi-fi Wigwam where there's more perverts for that sort of thing 😍I must take some pics of my multi strand ... darn ain't it sexy ...
I agree with everything you have said here 🙂 My point was just to show that not all optical cables are the same 👍Toslink was never designed for 192 (1st generation was only 48) and currently only rated up to 96, and that assumes the equipment it is connected too can manage it. (Remember the electrical input gets converted to light and then converted back at the end)
There is very little music that is true 192 (Most is just upsampled as studios use mainly 48 or 96 for mastering) so a bit of a niche for most users, (Plus a lot of Hi-res when tested is actually worse than 44.1 (Going above 44.1 is pretty pointless as there is virtually no music that goes above 20K) as unless very young their hearing is not good enough. (Many people consider themselves to have good hearing, but get a big shock when professionally tested, as in most cases it turns out to be not as good as they thought it was)
Bill
