Source to amp to speaker ratio
pravstar
24
I was wondering if anybody uses a specific ratio ,just for example my current set up now original rrp went from
Source £850,amp1k, speaker £700
To source 1k, amp 1k, speaker 1k
Now Source 1k, amp 1k, speaker 2k
I just found that adding a more expensive speaker each time got me closer to higher end audio.
The source did make a vast difference too even though the rrp price was negligible.
I have used the same amp throughout .
I was just curious/nosey, to see how other people divided their funds ratio wise in hi fi , instead of monetary value you can use ratios or both if you wish
Feb 18, 2015
58
I don't usually work within any kind of rrp ratio . just as long as the system is nicely balanced but usually find that the rrp values are all pretty close within two -three hundred pounds of each other....also,with the leaps in modern dac technology you can get away with spending probably the least on these if you plan on incorporating one.....I'd happily run a chord Hugo with amplifiers and speakers of many times more the rrp value.but with turntables/carts I'd be looking for a more balanced set up price wise.
lindsayt
16
Main system:
Tape source: 8%
Vinyl source: 22.5%
CD source: 0.15%
Passive pre-amp: 1.5%
Power amp: 12.5%
Speakers: 55%
Cables: 0.3%, Stands 0%.
Upstairs system:
Vinyl source: 53.5%
CD source: 0.3%
Active crossover: 3.5%
Power amplification (1 x SET, 1 x solid state): 32.5%
Speakers: 9.5%
Cables: 0.5% Stands 0%
AV system:
Freesat box & dish: 9%
Blu ray player: 3%
AV amp: 14.5%
Projector: 30.5%
Projector screen: 3%
Speakers (x7 various): 37%
Cables: 1.5% Stands: 1.5%
Kitchen system:
CD player: 4%
Amplifier: 28%
Speakers: 62.5%
Cables: 5.5% Stands 0%
lpv
47
source £100 ( wireless, lossless transmitter)
active speakers with dac and preamp £2100 ( no speaker cables, no interconnects) just power cables and 1 optical
CnoEvil
556
8
Some thoughts (all imo)
- As a source, Vinyl plays to different rules and requires a much higher percentage of the system.
- The Source has a bigger effect than is often realized and needs to be of a sufficient quality, so as not to hold back the system.
- Speakers seldom have an amp that fulfil their potential.
- A good streamer/dac (like Linn DS), if well designed, should sound better than the equivalently priced CDP, so is the best sound per pound.....IMO.
- My system - 15% on the Source and the balance split evenly between Amp and Speakers.
- I would rather have the speakers properly driven, than showing up the amp.
friendly_ghost
17
My setup is currently source-heavy (the TT-side that is).
TT: 2400€
CD: 500€
Tuner: 100€
Amp: 500€
Speakers: 1000€
So my next move will be an amp!
Vladimir
220
Why do people put hifi in their kitchen? Wouldn't the bathroom be a better location?
newlash09
219
45
10,820
My combo :
Source - 0
Amp - 58%
Speakers - 42%
IAM looking for a source. But considering poor streaming options available at my place. Not going to buy anything for source at the moment.
But good thread. Made me realise what budget I need to atleast consider to get a balanced system. Does it make sense to buy something like the azur 851N to play MP3 from a hard drive :)
Vladimir
220
S1 - Main
Source: $50 (2014) - 0.5%
Amp: $280 (1978) = $1,047 adj. for infl. - 10.5%
Speakers: 10,000 DM (1991) = $8,910 adj. for infl. - 89%
S2 - Desk
Source: $43 (2017) - 10.2%
Active Speakers: $380 (2016) - 89.8%
S3 - Cans
Source: $30 (2015) - 8%
Amp: $55 (2015) 14.6% + LPSU: $52 (2015) 13.8% - 28.4%
Headphones: $240 (2014) - 63.6%
CnoEvil
556
8
Vladimir said:
S1 - Main
S2 - Desk
S3 - Cans
Which do you prefer and if you could only keep one, which would it be (if different)?
Vladimir
220
S1 would be my choice. Unfortunately my 1987 Denon DCD-1500 mkII is RIP. It's would cost $1,700 in todays money. So the balance is now way off.
ASK THE COMMUNITY
