Vladimir said:Anything touched by Rick Rubin sounds rubbish. *boredom*
MeanandGreen said:Overdose said:Bass heavy tracks are usually produced that way because that is the style of the music.
I own a lot of music which you could regard as orientated around bass from the 80's, 90's 00's etc... however nothing is as bloated as the stuff in the last 10 years or so.
Thompsonuxb said:Lol
I have to agree with Overdose.
While tracks may be eq'd louder the quality on more than a few of them is good. It's what I've found going back and fourth through the decades.
One example is comparing Pharrel Williams 'girl' (the album with 'Happy' on it) 2014 with my reference CD from 1996 D'Angelo's 'Brown Sugar'.
The 2014 recording is eq'd pretty loud. Around +3db average the 96 eq'd around 0db peaking around +3db on the vu
Both albums are well recorded and dynamic.
But for Girl not to sound overly aggressive requires me having to turn it down.
Say for standard listening you set your volume to 9 o'clock - try it at 8 instead.
We all get used to stuff and it's the same with the settings on our kit. If over the years you have become use to having your amp set to a certain level and in your mind it is the optimum setting for your perfect sound. Break out of it, re-adjust your mindset.
Lol....that may sound silly - the control of the loudness is in your hands.
Thompsonuxb said:Modern recordings are better today on CD.
Well for the type of music I own and listen to.
Been playing Laura Mvula's - sing to the moon.
It's a jazz/folk/pop sound the production on the CD is top notch.
Initially I did think I had wasted my cash but with time some of the tracks are cool.
Its eq'd loud so don't forget to turn it down a little.
Track I find myself playing over and over 'Diamonds' track 12.......
If you're into comparing see how it stacks up against those 80's CD's and old vinyls
BigH said:Thompsonuxb said:Modern recordings are better today on CD.
You have just picked 1 album, does not mean much. Yes some recent albums are well produced, ie Melody Gardot, Malia but these tend to be exceptions rather than the rule, many are over compressed for the mobile/car market.
Vladimir said:If a system is loud at 10 o'clock its made in the marketing board room, not in the engineering room. A typical domestic system should get loud after 12 o'clock.?
Thompsonuxb said:Most amps today peak at 9o'clock - sure your Roksan does too.
I've mentioned this a few times aswel
It's really simple: as long as there are technically illiterate (and I mean that in a factual, kindly way) audio equipment consumers who write such nonsense on forums like " .... amplifier XYZ really punches above its weight despite its small case size", an opinion arrived at with absolutely no technical insight as to how it operates, then we are going to have manufacturers mining that rich seam of consumers. One way to create that illusion - and it costs nothing to implement - is to arrange the volume control to bunch the power towards the bottom end of the volume control rotation. That is all it takes to give the illusion that the user has the reins of a mighty, powerful shire horse of an amp, when in fact, it is a puny, effete beast. It would fool 99.9% of so called audiophiles. You get the general ideahere.
The core issue is that the microphone to the speaker and on to the room itself are technical subjects which require a minimum of technical knowledge, or at least technical respect, to get the best out of them. When the science of audio evaporated in the 80s, the void was filled with junk pseudo-science. And that's when the marketing men really cleaned up. As far as I can see, there is hardly a single statement made anywhere in audiophile land that stands up to even high school science level scrutiny. How to restore some sensibility? Demand that those who mould opinions and warp minds get off their back sides and prove whatever point they wish to make. The tools are readily available in the internet communication age. Then decide for yourself.
"No proof? No listen."
Vladimir said:...You get the general ideahere...
Whilst I hear the generic word "300B" I am not really sure what type of power output that is usually associated with. I have been told that it could be around 7W per channel. My definition of a 'decent valve amp' would be one with an adequate amount of power to create quasi-lifelike loudness shades between the quietest elements in live music as we would experience in the concert hall, and the instantaneous peaks, or an acceptable domestic approximation to them. That needs power[/i], for which there is no[/i] substitute and it is vital to fully grasp that concept. A dog can pretend to be a shire horse until the heavy load is coupled-up, when the power limitation is obvious.
Amp, or indeed muscle power, is needed not for some machismo reasons but because speaker cones are heavy and to capture the fast transients in live music have to be accelerated, because their position in space determines the peak loudness they generate. If they cannot demand the power from the amp, because it's underpowered or clipping, the cones cannot take up their correct position as the music demands fore and aft of the rest, and what you hear is therefore not a faithful representation of the music waveform. It's that simple which is why strangling the speakers with a small amp, or a big on that is clipping, is complete and utter madness.
It has to be accepted that it is not safe or practicable to reproduce the true loudness of the concert hall at home; nothing remotely like that level is possible, so all home listening is about creating a sound-in-miniature that gives enough mental cues that we can suspend disbelief and kid ourselves that we are really there. In effect, our audio set-up and our room at best approximates to a dolls house version of sonic reality: complete in the details, but at a tiny sonic scale.
How much power you actually need depends upon numerous factors, including your type of music, how far you are away from the speakers, how loud you like to play on average, time of day, neighbour/children considerations, speaker efficiency and so on. I gave careful though (as you would expect) to what I consider sensible minimum power recommendations for the speaker driving amps, based upon a lifetimes of listening to live concerts and listening at home, with equipment that shows me how much power is being demanded by the music from the amplifier (yes: it is that way round). We could though disagree to disagree over power minima, but what we cannot surely disagree over is the simple fact that a full orchestra, playing at an average plus loudness, needs one hell of a lot of amplifier power at home to begin[/i] to reproduce it with passable fidelity.
How many watts of human muscle effort are being converted to sound in this clip? Can that total wattage be reproduced as faithful sound over normal 1% efficiency speakers with a handful of amplifier watts? You must decide how lifelike your home audio realism expectations are. My guess is that the conductor alone is probably expending much more than 7W and remember: normal speakers waste about 99% of the electrical power that flows into them as soundless heat[/i].
Vladimir said:So basically a Shetland pony is a Ferrari
Vladimir said:That alert thingy didn't work...
Happy_Listner said:.... and 1990's 16 bit 44.1kHz was and is inferior.
