Samsung UE55KU6400
SONY BDP-S7200
Yamaha RX-V675
SONY PS4 Pro
Hello
Im after some advice regarding ,outputting the sound from the TV ,to the AV amp .Currently I have all my devices connected to the amp,and the amp connected to the TV.
Because my AV amp does not support 4k ( I could be wrong ?),I was advised to connect the devices directly to the TV,then ouput the sound to the AV amp.
With the sound coming via the TV ,will the signal still be the same quality as the direct connection,ie HD DD 5.1 ?
If this will produce the same signal,what is the best method for doing so,what HDMI port,which settings need to be changed?
Thank you
SONY BDP-S7200
Yamaha RX-V675
SONY PS4 Pro
Hello
Thank you
