With a fine sense of musicality and effective noise-cancelling, the WF-1000XM3s set a new benchmark for true wireless earbuds.
Sony WF-1000XM3 : Read more
There is a setting in the app - connection stability vs sound quality. Did you try the connection stability preference in a crowded place?Unfortunately I found they suffered from bad Bluetooth connectivity,
If you look in detail - many of the ratings on amazon are not relevant anymore.WHF review - 5 stars. Amazon reviews - 3 and a bit. Do these magazine reviewers actually leave their listening room to test this type of device properly i.e where it is supposedly designed to be used?
Yes I did but no difference. In any event why should I be forced to compromise on sound quality because these earbuds can’t maintain a stable connection. Others (e.g. AirPods pro) don’t seem to have ‘this problem.There is a setting in the app - connection stability vs sound quality. Did you try the connection stability preference in a crowded place?
Well the experience certainly didn’t improve for me. In fact I first noticed the unstable connection problem after the most recent firmware update.If you look in detail - many of the ratings on amazon are not relevant anymore.
With recent firware updates the experience has much improved. And YES, after last upgrade you can even use the earbuds as handsfree for phone calls
These earbuds do sound great. Unfortunately I found they suffered from bad Bluetooth connectivity, particularly in crowded places where lots of other people are using Bluetooth devices (e.g. Victoria station at rush hour). There is constant stuttering and break up of the connection. I’ve now tried two sets of these and both have the same problem, which makes them pretty much unusable for commuting. I‘ve taken both back for refunds and now use Apple AirPods pro which don’t suffer from this problem at all.
I bought theese after reading the review because I wanted a flexible listening solution.
They sound absolutely terrible, have no frequencies below 500Hz and terrible harsh treble.
I've tried all equalising settings; there's now way theese deserve the high rating.
My IPhone speakers sound a lot fuller and better.
I have the Sony WH1000xm2 'overear' which are decent, the XM3 are useless and can only be used to informative 'speech' - not music.
Don't buy without right of return.
So disappointing with this device. I updated firmware and still badWith a fine sense of musicality and effective noise-cancelling, the WF-1000XM3s set a new benchmark for true wireless earbuds.
yes, and forget to tell you - where is noise cancelation?? i didn't find anything workable for ios.hello dears, sound is good, but try to receive the phone call when you listening some music or even not listening - iphone mic will be not connected, and you have only to do such connection manually... just try. i tried different iphones - same result, unfortunately, latest ios, latest f.w for sony. pity
also i wrote and call to sony support - and even put them in service center. no news - sony support recommend ask to return to point of sales. very simply!yes, and forget to tell you - where is noise cancelation?? i didn't find anything workable for ios.
