Sony TV 40-46inches
Hi gel,right here are the setting's i use now im at home.These setting are what i find for a stunning picture,As i see these tv's everysingle day.remember you have to use the setting's on every imput.
target inputs-current
picture mode-custom
backlight-2
contrast 75
brightness 50
colour 50
hue 0
colour temp-neutral
sharpness-min
noise reduction-off
mpeg noise reduction-off
motionflow-standard
film mode-auto 1
advanced settings
black corrector-medium
adv.contrast enhancer-medium
gamma-0
led dynamic control-off
auto light limiter-off
clear white-low
live colour-medium.
Also turn off the ambient sensor,then go into eco settings..power saving needs to be off,idle tv standby set to off.then pc power management set to off.I think these setting's will blow you away..if you have the latest star trek film on blu-ray then put it on...it's a stunning test disc.hope this helps you,please let me know what you think.
Wow, cheers mate
I don't get the tv till next week, so i will let you know how i get on somtime towards the end of next week.
Cheers for doing that much appreciated
gel:
Just the tv Max, i am not interested in 3d but at a later date it might be classed as a benefit for me.
ok, i think you made the right choice getting a 46in, after having a 50in for a while, 40in would seem small, and 3d should look great at that size
If your not getting it til next week i dont know why you didnt order the hx903? mind you saying that they have already delayed it by ?months, im just hoping they stick to their word and ill have nice suprise waiting for me in the shop when i get back from my holidays
so gel, how do you find your new tv? how does it compare with the v20? are you going to get the 3d transmitter and glasses?
maxflinn:so gel, how do you find your new tv? how does it compare with the v20? are you going to get the 3d transmitter and glasses?
Hi Max cheers for asking
It is very different from the V20, blu rays look really good, normal pictures are really good too, sound i am finding quite good too.
I am still getting used to it, the size is great, i will post a picture of it and include the speakers and pioneers as well
But i have been very happy with it, i like the design too.
Cheers Mate
I don't know with the 3d part, it is being looked into.
maxflinn:gel:
Yep 40inches would have just been two small for me now, i did most of my demoing with the 40inch and they just looked the same but with the 46inch one being bigger.
sonycentre:Any time gel,enjoy your new tv.
Hi mate, really enjoying the tv
I have tried a couple of the settings, is there a way to do a factory reset back to the normal though?
ah thats great news that your happy gel
, i have to say i was impressed with that sony when i demoed it, lovely sharp picture, i might have got one myself only they are very expensive here in ireland
i think you will love watching those 3d animated movies on it, providing of course that you get the 3d bits and pieces, i have a feeling you might
Gel
Not sure if you noticed in what hifis review of the 40" version of your set that they stated that in 3d mode the brightness is ramped up and it reveals patchy backlighting (again) I have seen this in other reviews too mate! Not sure if it effects the 46". You may want to check this out if you have money left for the add ons that is!
Jamie.
sonycentre:
picture mode-custom
backlight-2
contrast 75
brightness 50
colour 50
hue 0
colour temp-neutral
sharpness-min
noise reduction-off
motionflow-standard
film mode-auto 1
advanced settings
gamma-0
clear white-low
live colour-medium.
I have just tried these on my ex503 and what a difference it has made to the picture much better many thanks my friend.
sonycentre:
picture mode-custom
backlight-2
contrast 75
brightness 50
colour 50
hue 0
colour temp-neutral
sharpness-min
noise reduction-off
motionflow-standard
film mode-auto 1
advanced settings
gamma-0
clear white-low
live colour-medium.
You might find it a stunning picture, but youve psysically changed the greyscale. Clearwhite should be off. Live colour should be off, contrast enhance should be off, black level should be off and auto should be 2
All youve done there is screwed about with colours making them seem more 'in your face' than they should. Pictures will 'never' look natural (Which they should)
Each to their own........
maxflinn:
I think you made a great decision too Max
i nearly did something similar, but this sony is so light too, it clinched it for me in my system.
I have looked at the 3d part, but i would have to put the 3d blu ray player on top of my pioneer blu ray player and then have my sky hd box on top of that. I know other people have pilled them up but i am not too sure what a professional opinion on that is anyone?
Snakey:
Gel
Jamie.
Cheers for the heads up mate
I have read the review i am not 100% sure i know what patchy backlighting is though and what too look for does anyone have any advice for me here?
I have demoed the 40inch and 46inch in 3d and can do again quite easily, so if someone can point out to me what it is? that would be great
Also would it affect you much? i mean i can see the 3d aspect definetely works on the 40inch and 46inch.
gel:Snakey:
Gel
Jamie.
gel, my advice is just enjoy your new tv, if you see problems of any kind then contact the retailer
Cheers Max
will do.
What do you think to putting a blu ray player on top of another one?
Cheers.
gel:
Cheers Max
will do.
Cheers.
not a problem imo, players dont run hot, ive got a big heavy amp on my cd player and its fine..
just dont put anything on your avr
maxflinn:gel:
Cheers Max
will do.
Cheers.
Cheers mate
i have seen others do it, just wanted to double check though.
I thought about having it separate from the system, to use it for blu rays without the speakers and for 3d incase i wanted too.
Or i wait and see what pioneer do, but i am guessing it would be really expensive that way when they get there act together.
maxflinn:gel, you should consider the panasonic DMP-BDT300 , £269.97 here, it has dual hdmi ports, one for your tv and one for your avr, sorted..
Yep
that certainly would be handy having those dual hdmi points i am amazed others have not done it, that is a good deal, i think if i had a choice i would prefer a pioneer or a sony blur ray player but that is certainly something that would be very handy here.
Cheers mate
gel:What do you think to putting a blu ray player on top of another one?
Not the way to get 3D - and anyway, synchronising the two discs would be a nightmare.
Andrew Everard:
Hey Gel
As max says better not to go looking for trouble but if you do notice inconsistencies in the screen ie if you see lighter areas on the screen often in the corners(like mine) this is referred to patchy back lighting or bleed I did see a Samsung one of the 55 inch side LED lit LCD and that had terrible blotches in the picture one huge patch in the middle of the screen but that was with the light all the way up as they always are in stores. The way i read it from the reviews from the hx803 is that in 3d mode the back light is ramped up so any inconsistencies are made more obvious!!!
