In theory you do have a valid point - IF the manufacturer's support team responds in an intelligent, informed, sensible and correct manner, but that was very definitely not my impression of the person I spoke to at Sony yesterday.
It was clear that he was not at all familiar with the product in question, or its intended use - and this is not good for the support of a product designed for incorporation within a home cinema system, especially when, for the company concerned, it is a relatively high profile item which is relatively widely advertised and sold.
The guy had difficulty in understanding how it is connected up, and that it was displaying the same symptoms whilst disconnected from the system as it was when connected to the system. Those symptoms are simply that the blue front panel indicator comes on about 15 secs after power is applied, stays on for another 10-15 secs, and then goes off again; and will not come on again until the power from the PSU is disconnected for at least a couple of minutes - and then does exactly the same thing again! Of course, misfunctioning like that causes it not to handshake adequately with the AV amp (Onkyo 609) and so the latter briefly picks up a signal from the SMP-N200 and then loses it again after 10-15 secs (max).
He then had to ask someone else as to "what to do next" - which was, as I had just suggested to him (!) to try the Reset function (there is a small push-switch recessed behind a hole in the bottom of the unit case), and which, by the way, had no effect. Thus only after some 20 mins on the phone, did he finally accept that the unit appeared to be faulty!
Also, the fact that I actually got through on the phone to the same person after a further gap of some 20 minutes or so (when I was trying to contact the service agent) indicates to me that the Sony technical support team for this range of products is very small indeed! Therefore my confidence in Sony's ability to adequately support this product is substantially diminished!
Hopefully the replacement unit will be more successful and reliable - and, BTW, the replacement arrived from Amazon whilst I was writing this email at around 8.40am on Saturday! Good work, Amazon but it was still a most unnecessarily time-consuming and "blood-pressure raising" exercise to have to go through all that I went yesterday afternoon in order for this to happen!
And, BTW, I wonder if the new unit does actually support Netflix "out of the box"? We shall see and I will post what I find.
John
