Sony S370 - S470 - iPhone/Touch remote
mattjax05
230
Quick question.
If you want to use the iPhone/Touch as a remote I take it you need to get the dongle to enable wifi unless you plug in an ethernet cable?
Thinking about getting the S470 anyway as it can be had for £170 (around £30 more) and it's natively wifi enabled and 3D compatible (with an upgrade)
Can you view info on the remote app such as disc/chapter position etc?
Matt
If you mean the S470 has built in wifi I don't think it does, according to the Sony website you'll still need the dongle
