sony 37w5500 vs samsung le37b650 time to decide!! buying tonight
Make sure you get a good look at them both - particularly the Sony which, if our experience is anything to go by, needs the uniformity of its backlighting examining carefully.
Im using an external hifi for sound. So am looking primarily for the best picture above all else, and i won't be using the freeview facility! i haven't found anywhere where i can compare the two. have only seen the sony in standard definition!
i bought the b650 and its amazing! the mediaplay function is superb! i use its built in freeview and the pic is great!
i bought the 40in though as sammy and sony dont make there own 37 in panels 40in only 5cm bigger and awsome!
