Sony 37W5500 or Samsung LE37B550?
Hello all, hoping to get an expert opinion on the following question.
I have found the Sony 37W5500 for £600, and the Samsung LE37B550 for £450, and don't know which to opt for. The WhatHiFi best buy would recomment the Samsung, but presumably because it is so good at its low price point. But, price aside (bearing in mind there is no longer much of a difference), which is actually the better TV?
Any advice would be greatly appreciated.
there probably wouldnt be much in it between them , but the key difference , is motion processing , the sony has 100hz motionflow , the samsung doesnt , now some people wouldnt mind that , but how do you know if your one of them ?? i would want the 100hz myself , as im quite picky , and would notice any motion blurring , some people are not bothered though , and the samsung is said to be quite good with motion , even without the 100hz , you need to demo to be sure , find a shop with both, ask the salesman to turn motionflow on , using its lowest setting on the sony , and compare , its the only way ...
