Sony 360 or Sony 765 blue ray player
What would you recommend between these two Sony players? The 360 cost GBP190 while the 765 cost GBP360 with one free BD disc and is a made in Japan player. Which player would provide a better pq? Thanks
Firstly I would say both the S360 and S760 are fine blu ray players.
Secondly, the price you've quoted sounds a little steep - for example you can get them at RS for £120 and £299 respectively, OK it's without any blu ray disks - but you can get these for about £10 if you shop around...
Thirdly the big differences between the S360 and the S760 is the m/c audio out and improved video/audio components. You only need the former if you've got an amp that doesn't take HDMI (like mine doesn't) and the latter gets to be a matter of personal taste; though if you've got a big screen (>=40") or projector you will probably see the difference.
The 3D enabled or enablable (?) sony BDPs come out later in the year, the S770 is rumoured to be about £250-300, similar specs to S760 but with faster load times and 3D...
Thanks for your replies. I am from Malaysia. The actual prices for the S360 and the S765 are GBP282 and GBP378 respectively sold iMalaysia. I am using an old Denon AVR-1803 receiver, using optical to link the player to the receiver but for video I will be linking by QED HDMI to a Sony 40 inch FHD LCD TV. I intend to change my receiver to an amp with HDMI connections in the near future.
