Sonos ZP120 with Floorstanders. B&W 684 or Monitor Audio BX5 for example?
h4rdy
21
Hi everybody,
Out of all this a little as I went to the Home Cinema darkside and have now decided, due to lack of use, that I would like to go back to a dedicated HiFi.
I run a couple of Sonos Zones. One in the Bathroom with a ceiling speaker. And one attached to my Arcam Solo Movie 5.1.
I am considering selling the Solo Movie, ZP90, and B&1 MT1s/PV1 and replacing them with a ZP120 and the above floorstanding option.
I will be adding a S5 zone at some point too.
Any other speaker options, I don't really want stand mounts as I prefer the look and sound of Floorstanders.
I will also be using the input on the ZP120 for either my Pro-Ject Turntable or TV.
Am I barking mad?
Thanks in advance.
BW 684 are £699. In that price category there are Also:
Dali Concept 8 (£635), Acoustic Energy Aelite 3 (499), MA BX6, RX6, Wharfedales 10.7, and more with an RRP around 1k available as ex-dems for around 700.
Yes thanks I will have a listen to all my choices and the ones you suggest.
I wasn't limiting myself I was just giving examples although I have always liked B&W.
For "dedicated" hi-fi it seems like an odd idea to me, I'd keep the ZP90, get a decent DAC and a stereo amp and use that. The ZP120's not a bad amp, as they go, but you can easily better it and going for seperates from a ZP90 gives you more upgrade options in the future (if you get into 24-bit audio for example).
If you've already got the ZP90, I'd hang on to it and consider getting a stereo amp (maybe with DAC) and speakers. Not selling the Sonos should put about £150 extra in the pot (my assumed difference between a new ZP120 and selling your ZP90 on e-bay). With this you should be able to get a decent stereo amp and floorstanders. To stretch your budget further, look at secondhand...
I understand what your saying and maybe 'dedicated' hifi was a bit strong.
One of my other reasons is to cut down on boxes, especially speakers, but if I was to get an amp and keep the ZP90 surely it would be a good idea to keep the Arcam and use it in Stereo.
I would also get the advantage of having a CD player too?
Or is a dedicated HiFi Stereo amp always going to be a better option?
I rip in Lossless although TBH its hard to tell the difference between that and 320kpbs sometimes.
As the Arcam is now discontinued I guess I would get around £500? Is that a reasonable amount for an Amp?
The Money from the Speakers I have would go towards the new Floorstanders.
The Yamaha AS-500 looks like a nice bit of kit but I think what I will do first is audition a ZP120 with some Floorstanders.
I can then see if its what I want.
Any other suggestions more than grateful.
h4rdy:
You could, but you've got lots of unnecessary circuitry and although Arcam's are more musical than most AV amps, a dedicated stereo amp is going to be better. More import is the fact that the Arcam has digital in and its own DAC - which would allow you to use the spdif out on the SONOS, and in my experience Arcam's Wolfson DAC outperforms the Sonos one.
Almost certainly. Though this depends on how much you spend on your amp...
I can tell the difference on my set up, using a ZP90/Arcam AVR250 and a pair of Monitor Silver 8is. How have you got your SONOS plumbed into your Amp - spdif or phono?
You should be able to get more than that. There's one on eBay at £899 at the moment, for a used one. £8-900 buys a very good stereo amp, and if you look at secondhand, some fairly stunning ones...
Makes sense. Maybe talk to your local friendly dealer...
Thanks for all your help Scene.
I need to see what I am trying to gain from all of this as well.
Your right about the Solo Movie having lots of unnecesary ciruitry.
I have the Sonos plumbed in at the moment with RCA as using the internal on the Sonos.
Don't know why actually maybe I ran out of inputs due to TV and PS3!
But that will all be irrelevant anyway as I won't be using it for that.
I quite like the look of the smaller sized Cyrus amp.
I used to a have a Mission Cyrus 2 and PSX back in the day!
Try a decent coax between the Sonos and the Arcam. It's digital and Arcam usually recommend coax over optical for spdif for quality. Might be worth a spin, just to see what difference it makes.
Rather than throw the baby out with the bath water, you might want to see if you can demo some full-fat floorstanders with the Solo, so you can have the best of both worlds - surround sound with decent stereo... This is sort of what I've now ended up with in my living room with the AVR250 + Silver 8is and some RXFX + RS-LCR to give me 5.1 when needed. Sounds great, and not too much of a compromise. Still have the A85 to go for purist stereo - when I sort out some new speakers ...
Thanks again, I think I will have a chat with my dealer and see if I can demo some floorstanders at home.
I will get my ZP100 out of the bathroom zone and give it a demo maybe as well as with the Solo.
Again many thanks.
So a rethink has happened and my current plan is to sell the B&W package and keep the Arcam as I found out it can be bi-amped/wired.
I am going to try and buy some PMC DB1i second hand and run these with my Arcam Bi-Amped.
If its rubbish I will get a new Amp but should be good enough as a temporary measure!
No room for floorstanders anyway.
