some updates
Sorry Clinton,i thought your arcam was a stereo amp 😳
I'd be interested to know if the 105 sounds better doing the processing for film sountracks (as opposed to your arcam)on your reference system
clinton333 said:
I will give it all it's first full length feature workout tonight and see what happens... Just need to get down to my not so local now Blockbuster :doh:
How did it go?
FWIW. Run the Sub's EQ before running that of Arcam...ie. when you have found the Sub's final position.
No worries mate...
I have to be honest I have only used the analogue out for 2 channel (cd playback) and not surround... FWIW I love the sound from using hdmi into the Arcam... It's epic :grin:
CnoEvil said:
How did it go?
Still not there yet... :wall:...
Yes I will certainly get the sub all setup prior to running the Arcam EQ... Do you use your EQ at all out of interest?
clinton333 said:
CnoEvil said:
How did it go?
I did originally, but when I added the 35i through the Pre-Outs, I couldn't get it to work.
I may go back to using it, if I get R100s to cope with L&R through the AVR600.
No worries mate...
Me too,must admit i'm very intregued as to the differance in sq between the arcam and my yamaha..... 🙂
GSB said:
R100's :?
Yup.
ATM, the L&R are left switched off a lot of the time for AV, as the 35i is expensive to run outside of 2 channel. I will be quite happy using the R100s in this role, as HT is less important to me (and the Centre is way more important anyway). This leaves my AV and 2 Channel independant of each other.
I thought you had kef Ref speakers?Didn't know you had a pair of R100's aswell....wish you would put a signature up... :grin:
I have 205/2s connected connected to the 35i (also covering L&R in 5.1 at present).....but dismantled atm due to house being turned into a building site.
I don't have R100s.........yet.
My system: http://www.whathifi.com/forum/your-system/and-finally
Even tho the R100's(looking forward to hearing your thoughts on them) are going to be for AV,i thought you would prefere the LS50's,or even the R300's.
Without taking over Clinton's thread how's the building work going?Hope the end is in sight,and your HT/HIFI set-up get's back to normal.
Never seen your system before cno. All I can say is WOW! That is a dream system. Do you not have blu ray or am I being dumb?
I do prefer the LS50s, and would take them over the R100s for 2 Channel.....this is a cost saving excercise.
Re building work - still demolishing, I'm afraid.
As you can see, I have the DV79 DVD Player; and can dragoon in the kid's Sony PS3 when I want to watch a Blu-ray.
Trefor Patten said:
their, airborn, principal. It's a good job you're not 11-years-old and sitting your grammar and spelling SATS.
Hedding twowards 9000 posts, meny off them rarther convelooted....I'm aloud the od misstake, surely. :shifty:
Your defanatly right about the center channel tho cno,the other evening i forgot to turn on the MF,took over an hour to realise i wasn't getting any thing from L/R :roll:
