I have ordered sky HD and need help to be ready to connect in 2nd tv.
The hdmi will go to plasma so the main screen is sorted.
I need to connect the 2nd out to a 2nd TV. This will either be next door, up upstairs above the box.
So i either will have to go through the wall, or through the ceiling - not the best options.
A scart if that the best connection will obviously need a bigger hole, which isn't good.
do the boxes have component or composite outs? they would probably be easier to route, or should i just run a coax - I could run this under the floor, outside, up wall etc, run length would be probably 30 m.
Any advice would be good. (2nd tv's are crt at present)
