I have to run a 2 Sky cables through my loft and down a cavity wall before sky fit the HD box, what is the best cable to get for this, the run is about 50 ft.
daveh75
i always use pf100 cable its 75ohm double screened cable that has copper centre core and braid, plus copper foil screening, and is the "sky approved" stuff, some of the cheaper stuff available has a steel braid and silver foil screening, which if you use, the sky engineer may refuse to use as its not "sky approved" ,
