Sky box to PVR to TV
mattjax05
230
I would just like some clarification on the above please.
I would like to record Sky using the PVR so do I connect the two using Scart? I would also like to use the Freeview in the PVR so do I connect the PVR using RF2 out on sky box (the aeriel signal is sent to the Sky box)? And for viewing I connect Sky to tv using either RF1 or Scart and PVR using Scart?
Thanks, Matt
daveh75
mattjax05:
I would like to record Sky using the PVR so do I connect the two using Scart?Yes.I would also like to use the Freeview in the PVR so do I connect the PVR using RF2 out on sky box (the aeriel signal is sent to the Sky box)?Either the RF1 or RF2 And for viewing I connect Sky to tv using either RF1 or Scart and PVR using Scart?
Thanks, Matt
Use scart to connect both Sky box and PVR to the TV. PQ via rf is poor.
mattjax05
230
daveh75:mattjax05:
Great. Would you then use the PVR via it's own remote to handle the recording of Sky? Does the PVR see the Sky's EPG so it knows when to start and stop the recording.
Which pvr do you have? because this is generaly not possible you need a dvd recorder. Generally PVRs will only record from their own tuners.
