Single channel speaker delay. Help.
pogologo
7
I hope someomemcan help. I have arcam solo from new for about 6 months. It has been fine, but it seems to have developed an echo (a delay) through one of the speakers (2.0 setup).
Anyone have any idea why this would be? Happens on all sources. Speaker cables all right and secure etc.
Al ears
Moderator
Very odd. Send it back under warranty.
amormusic
202
105
10,970
Send it back... Arcam warranty is really good...
You will be covered by 5yr repair or replace warranty (I know this as I had a recent issue with my A29 amp). You might need to register it with Arcam first if you haven’t already done this. Should be a leaflet in box with website to do this on
Takes about two weeks and it’ll be back and fully operational again. Good luck!
jimmy1
17
I had the same problem but it turned out id wired one speaker out of phase.
gives the same echo/reverb effect
nopiano
648
398
19,270
That’s a good shout! I’d been scratching my head on this until now.
If the op switches the wires to just one speaker there should be more bass and no hollow effect, if that’s the cause.
The only proviso is he said it developed, which is more puzzling. I’d wondered if there was a cinema setting with delay options, but I’m not familiar with the Solo.
jimmy1
17
Yes its strange fault to just develop on its own but i dont know anything about the solo neither.
Strictly Stereo
How bizarre. Is it a delay or an echo? How much of a delay and how loud is the echo relative to the original sound (best estimate)?
ASK THE COMMUNITY
