silly question
smuggs
347
chord supershield hdmi cables are they green or blue or is it the luck of the draw when you buy one.
Very difficult to get an accurate colour match on a website.
For example here's the same picture on Chord's PR company website (right), and (left) when I download it and open it in Photoshop
Andrew Everard:
So is that green or blue then?
Well alright then, more azure than turquoise. Just been hunting through a pile of cables to try to find one, so I can more accurately describe the colour, but I don't have one to hand.
Whatever, the point is that there's only one colour, and that's what you get when you buy the cable, so to answer the OP's question it's not 'the luck of the draw when you buy one'.
