Hi Shadders
The amp showedfive bars on the display. That, according to the manual, indicated a speaker or cable issue. Returned the amp to Roksan. Received back today with new motherboard. Connected it all up and now discovered that the left hand speaker midrange unit has burnt out. Speaker is now with dealer for repair.
As suggested, I have tried swopping amp speaker outputs around, bought new speaker leads and tested the speakers with a Sony AV amp without issue
When speakers burn out, they can often present a short-circuit to the amplifier. That can be the driver itself going short, or, if the driver goes open-circuit, the (effectively unloaded) crossover can present short circuits and weird phase angles.
The amplifier will try to drive those short-circuits, meaning it'll try to pass the hundreds of amps required. Of course, that much current is in the realm of very large high power amplifiers (I know this because I have a few of them - read up on the Crown MA12000i for example). A HiFi amp attempting that sort of current will fail, usually taking out the output transistors, probably driver transistors, maybe some PSU bits and pieces and anything else in-line with the speaker output.
Another point to consider is that the position of the volume control means almost nothing. If I connect my laptop to my HiFi, I can have the amp turned all the way up to 11, and then bring the volume down at the source and get perfectly sensible levels. Alternatively, I can connect up a professional mixing desk capable of +22dBU (10V RMS) output and barely have to turn the amp up at all to get maximum output.
It seems to me that you're asking too much volume from this particular setup. I looked up the PMC 23 speakers, and they're a floorstanding 5" 2-way speaker. They're never going to move loads of air or get particularly loud - I would strongly suggest that you replace them with higher sensitivity and more power handling. I'd go for either a pair of 6"s or an 8" midbass driver. More, if you can afford the space.
Hope that helps to dispel some mysteries.
Chris
