Hey, all,
I now have to opportunity to get the Rega Planar 3 turntable with Exact MM barely used second hand for 450£. The thing is that I'm e newbie and I don't know what to look for when getting it to check if it is OK. And unfortunately, getting it home to test listen is not an option.
So what is your advice, should I get it? And is there something I should check for to make sure it's fine?
