Hello good people, I have a question regarding the correct set-up for my newly acquired Linn Sondek LP12 which came with the Audio-Technica AT-1005 Mk2 tonearm fitted with an Audio-Technica MG9 headshell and Goldring 1012GX cartridge. Now, I decided that I did not like the MG9 as it was quite oxidised and unattractive and it also has a very small finger lift and, given that I have no arm lift fitted to the tonearm, it was quite tricky to place the stylus in the groove accurately. And so, I have now changed the headshell for an Audio-Technica S8, which I believe is the one that would've come with the arm before the MG9 'upgrade'.
In order for me to set up the alignment correctly I purchased a Linn LBL 025 'A' protractor with both the A and B alignment markings (see photo). However, I found that in order to get the cartridge to align with both marks (more on this later), I had to twist the cartridge in the headshell more than it had been twisted in the MG9 headshell previously, although I had not previously checked that the original alignment was correct. It just seems odd that the cartridge has to sit at such an angle in the headshell as can be seen by the position of the screws (see photo).
So I had a look at the original tonearm specifications and discovered that my tonearm base hole to turntable spindle distance is approximately 220mm compared with 225mm specified by the manufacturer. This would explain, I believe, why my cartridge has to be rotated in order to align it properly, although it still doesn't align with both A and B points perfectly. I've also calculated that my 'overhang' is 18mm rather than the 15mm in the original specification.
I guess my question is: does the position of the cartridge (offset angle) in the headshell matter if my alignment is good (but not perfect) and the overhang distance is 3mm greater than specified, or should I make further adjustments of the cartridge? Many thanks and apologies if this seems long-winded!
Note: Photo 1 shows everything; photos 2 and 3 show my best alignment, though position B looks very slightly off and that the cartridge wants to be rotated counter-clockwise very slightly, although this would then throw position 'A' off ; photo 4 shows how much the cartridge is offset in the headshell.
