Hello all. Been a while Since I posted.
Been playing about with my setup on these dark evenings! Listening to tunes from Node 2i via analogue Into LX82.
I have been using my sub on occasion for music. (Listening in direct mode). On moving the crossover up the way from 60 hZ to 100hZ. I think the sq is better At the higher crossover. Is this right? Music from the RX6 sounds thin with no depth at lower cross over. Been reading threads for movies you should set cross over +10 above your speakers low point? Movies sound fine. lower cross over 60hZ creates great low end bang from the sub.. Should I need to change cross over for music and movies. Have I missed something?
thanks all
john
thanks all
john
