Separating Hi-Fi Components
munchpants
13
I have been led to believe that an option to buying a hi-fi stand is some material or foam that can be placed between the units to avoid vibration. Does anyone know what this is and where I can get it from?
Not sure about foam but I think isotek make isolation feet which you attach beneath your components - there about £15. There essentially squash balls cut in half but are proven to minimise vibration
Try cutting squash balls in half and sitting them under each component. Am not joking!
[quote user="munchpants"]
[/quote]
To avoid vibration from what?
It will block the ventilation. Don't do it.
