its all for music:I have tried different positions for the speaker but I think the bottom line is I need a speaker with a weightier sound without loosing the openness. From what I have read, it seems that the EB Acoustics might be just the ticket. Has anyone had a chance to listen to Rega RS1's and the EB1's and/or 2's?
As most can tell you (and you undoubtedly know) the amplifier>speaker interface is the crucial one, leaving the room aside for a moment. So it would be more relevant for you to ask whether someone used these two EB designs with your amplifier. Even then, the room is equally responsible for how your chosen system will sound.
Iggleberts suggestion of Regas 3 does make sense if you like everything about your 1's and just want more bass, as does adding a sub. Both would be not much more space consuming than a standmount, especially the former, which has a small footprint and height. I don't quite understand how your 'other half' could object to that, especially when comparing to a large standmount, such as EB2?
As EB have a return policy, as you undoubtedly know as well as you've done some research on the subject, there's no risk. So where's the problem trying exactly? You seem to be pretty much settled on the idea and there's only one sure way to find out eh?
